JeramyK
May 15, 2021Tutor
Orbi RBR850 V3.2.18.1 DHCP Assigning IPs every few seconds
Related question: Why is model RBR850 not in the selection list for this post? I have an Orbi RBR850 with one satelite on firmware V3.2.18.1_1.4.14. I noticed that the logs were consitently filli...
JeramyK
May 15, 2021Tutor
I am seeing both wired and wirelss. The most common look to be the GalaxyNote8 (wireless) and the SonyTV (wired).
I havent been checking the MAC addresses long enough to tell if all devices are being reassigned more often than 12 hours but I will keep an eye on it.
W1lliam
May 20, 2021Virtuoso
Change your phone on MAC address as Phone MAC instead of Randomized MAC
- JeramyKMay 20, 2021Tutor
W1lliam wrote:Change your phone on MAC address as Phone MAC instead of Randomized MAC
The MAC address is the same for each entry in the logs. I also checked for the setting and it doesn't look like the Galaxy Note 8 has a Randomized vs Device MAC option.
- KMDonlonMay 20, 2021VirtuosoRandomized MAC is usually an option in developer settings
- W1lliamMay 20, 2021VirtuosoAndroid 10 has Randomized MAC set as default, Galaxy Note 8 sounds not on this, so your issue is not on MAC address related. It needs to capture packets in the air to judge what went wrong with DHCP packets
Since the issue is not isolated to the Note 8 I suspect it is not the issue. The same log excerpt without the Note 8 entries still shows multiple devices being assigned the same IP address within seconds, certainly shorter thatn the normal 12 hour lease.
[DHCP IP: (192.168.1.38)] to MAC address UnknownApple1, Saturday, May 15,2021 12:24:49 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 12:21:31 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 12:20:30 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 12:19:59 [DHCP IP: (192.168.1.30)] to MAC address iPhone, Saturday, May 15,2021 12:18:13 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 12:15:39 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 12:10:30 [DHCP IP: (192.168.1.33)] to MAC address Fire, Saturday, May 15,2021 12:10:16 [DHCP IP: (192.168.1.30)] to MAC address iPhone, Saturday, May 15,2021 12:07:02 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 12:05:00 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 12:01:14 [DHCP IP: (192.168.1.30)] to MAC address iPhone, Saturday, May 15,2021 11:57:00 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:55:56 [DHCP IP: (192.168.1.22)] to MAC address UnknownHP1, Saturday, May 15,2021 11:55:36 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:55:36 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:50:28 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:49:57 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:49:26 [DHCP IP: (192.168.1.33)] to MAC address Fire, Saturday, May 15,2021 11:47:24 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:45:42 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:42:59 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:41:00 [DHCP IP: (192.168.1.18)] to MAC address iMac, Saturday, May 15,2021 11:38:53 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:36:33 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:35:43 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:35:41 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:35:01 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:34:56 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:33:54 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:31:42 [DHCP IP: (192.168.1.30)] to MAC address iPhone, Saturday, May 15,2021 11:29:37 [DHCP IP: (192.168.1.30)] to MAC address iPhone, Saturday, May 15,2021 11:28:30 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:27:54 [DHCP IP: (192.168.1.30)] to MAC address iPhone, Saturday, May 15,2021 11:27:37 [DHCP IP: (192.168.1.30)] to MAC address iPhone, Saturday, May 15,2021 11:25:41 [DHCP IP: (192.168.1.37)] to MAC address eGage, Saturday, May 15,2021 11:24:19 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:19:55 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:19:24 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:17:25 [DHCP IP: (192.168.1.36)] to MAC address EpsonPrinter, Saturday, May 15,2021 11:14:52 [DHCP IP: (192.168.1.35)] to MAC address iPad, Saturday, May 15,2021 11:11:30 [DHCP IP: (192.168.1.31)] to MAC address FireStick, Saturday, May 15,2021 11:09:02 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:09:01 [DHCP IP: (192.168.1.32)] to MAC address EchoDot, Saturday, May 15,2021 11:08:03 [DHCP IP: (192.168.1.24)] to MAC address Playstation4, Saturday, May 15,2021 11:06:59 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:06:47 [DHCP IP: (192.168.1.34)] to MAC address iPhone2, Saturday, May 15,2021 11:06:02 [DHCP IP: (192.168.1.29)] to MAC address NestThemostat3, Saturday, May 15,2021 11:05:50 [DHCP IP: (192.168.1.26)] to MAC address NestThemostat2, Saturday, May 15,2021 11:05:48 [DHCP IP: (192.168.1.16)] to MAC address SonyTV, Saturday, May 15,2021 11:04:23 [DHCP IP: (192.168.1.28)] to MAC address NestThemostat1, Saturday, May 15,2021 11:04:12 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:03:35 [DHCP IP: (192.168.1.33)] to MAC address Fire, Saturday, May 15,2021 11:03:15 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:02:36 [DHCP IP: (192.168.1.17)] to MAC address OrbiSatellite, Saturday, May 15,2021 11:02:10 [DHCP IP: (192.168.1.33)] to MAC address Fire, Saturday, May 15,2021 11:02:08 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:02:08 [DHCP IP: (192.168.1.34)] to MAC address iPhone2, Saturday, May 15,2021 11:02:07 [DHCP IP: (192.168.1.20)] to MAC address AppleWatch1, Saturday, May 15,2021 11:01:08 [DHCP IP: (192.168.1.31)] to MAC address FireStick, Saturday, May 15,2021 11:00:55 [DHCP IP: (192.168.1.32)] to MAC address EchoDot, Saturday, May 15,2021 11:00:54 [DHCP IP: (192.168.1.29)] to MAC address NestThemostat3, Saturday, May 15,2021 11:00:50 [DHCP IP: (192.168.1.28)] to MAC address NestThemostat1, Saturday, May 15,2021 11:00:48 [DHCP IP: (192.168.1.26)] to MAC address NestThemostat2, Saturday, May 15,2021 11:00:42 [DHCP IP: (192.168.1.28)] to MAC address NestThemostat1, Saturday, May 15,2021 10:58:53 [DHCP IP: (192.168.1.26)] to MAC address NestThemostat2, Saturday, May 15,2021 10:56:45
