JeramyK
May 15, 2021Tutor
Orbi RBR850 V3.2.18.1 DHCP Assigning IPs every few seconds
Related question: Why is model RBR850 not in the selection list for this post? I have an Orbi RBR850 with one satelite on firmware V3.2.18.1_1.4.14. I noticed that the logs were consitently filli...
JeramyK
May 27, 2021Tutor
These look quite similar:
- https://community.netgear.com/t5/Orbi-AX/RBK753S-Issue-with-logging/m-p/1979600
- https://community.netgear.com/t5/Orbi-AX/RBK853-logging/td-p/1923262
No answers there either.
Along with the repeated DHCP lines my emailed logs also show an increasing number of entries like those shown in the links above.
i.e.:
Thursday, Jan 01,491926 -5:00:00 Thursday, Jan 01,491926 -5:00:00 Thursday, Jan 01,491926 -5:00:00 Thursday, Jan 01,491926 -5:00:00 Thursday, Jan 01,491926 -5:00:00 Thursday, Jan 01,491926 -5:00:00 Thursday, Jan 01,491926 -5:00:00
- CrimpOnMay 27, 2021Guru - Experienced User
JeramyK wrote:Along with the repeated DHCP lines my emailed logs also show an increasing number of entries like those shown in the links above.
i.e.:
Not a particularly helpful log message. If the issue is worth devoting time and effort to, my approach would be to capture LAN packets and examing them with Wireshark. Routers do not spontaneously assign IP addresses. Devices broadcast DHCP requests and routers respond to them. The DHCP response contains the lease time. If Orbi is assigning a very short lease, the device will ask to renew very soon.
- hkopppMay 27, 2021Star
firmware issue im having same issue latest firmware is the cause no other fixes thats netgear for you
hkoppp wrote:firmware issue im having same issue latest firmware is the cause no other fixes thats netgear for you
So manually loading previous firmware has fixed the problem? Is it present on certain firmware and not on others?
I really enjoy researching this sort of issue, but the devices on my Orbi renew DHCP leases every 12 hours, just as they are supposed to do.
