LukeM
Jul 28, 2020Star
Orbi RBR850 WiFi - SSID Not visible on some devices
I have an Orbi 6 Mesh Router with Firmware version 3.2.15.25_1.3.15. I have two sattelites and the install was fairly staightforward. However, since, day 1, the Orbi does not show up in the SSID list...
- Jul 28, 2020
Use the admin browser (orbilogin.com), go to Advanced... Advanced... Wireless Settings, change CTS/RTS threshold for both 2.4Ghz and 5Ghz to 2347. This corrects many wireless compatibility issues.
If that doesn't work, in the worst case you can uncheck Enable AX in Advanced... Setup... Wireless Setup. But it would be a shame to disable AX on your new AX router just to remain compatible with older devices.
Jul 28, 2020Guru - Experienced User
Please post about this over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
- LukeMJul 28, 2020Star
OK thanks, will try there. Actually wasn't sure where to post as couldn't find my model in any lists... Thanks for the steer...
Luke
- FURRYe38Jul 28, 2020Guru - Experienced User
Thats ok. you don't have to put a model in. NG should add the Orbi AX models to the drop down though.
- LukeMAug 10, 2020Star
Hi FURRYe38,
thanks for the heads up. I have tried to apply the update. For the two satellites, it worked fine, however I cannot get the router to accept the update. I consistently get an error that the update has failed but no indication as to why. Screen shots attached. Any suggestions? (PS. The PC is connected via Ethernet to the router as cannot connect via wifi unless I disable AX).
Thanks,
Luke- LukeMAug 10, 2020Star
FURRYe38 second screen shot. (I couldn't find a way to add more than one file to the same post).
Luke
LukeM wrote:Hi FURRYe38,
Thanks,
Luke - FURRYe38Aug 10, 2020Guru - Experienced User
What browser are you using? Try IE11, firefox or Opera.
I presume you are unpacking the .zip file.
Hi Furry,
I was using Chrome (which worked fine for the Satellite updates) but have now tried again using both Firefox and IE11. Router update fails with both of those too... (And yes, the file is unpacked).
Luke
