steveshead
Oct 10, 2022Guide
Orbi RBR850 will not connect to Starlink
I know there are a lot of other posts on this subject, but they all lead to a solution of adding a switch in between the Orbi and Starlink - which did not work for me. Things I've tried: Puttin...
Oct 11, 2022Guru - Experienced User
yeah, old settings could cause issues. I might even just try a factory reset and start back from stock in case you changed anything else that causes issues.
But FURRYe38 is right, use the 2.5gig internet port for connection
steveshead
Oct 11, 2022Guide
Thank you! After many tries, I got it working.
I reset Orbi to factory - then went through the setup process. The Orbi app kept telling me there was no internet connection so I went back to my Mac and logged in through orbilogin.net with the aim of restoring from backup. The odd thing was the online portal could see the internet, whereas the Orbi app could not. I finished configuring Orbi through the online portal.
So current setup is:
- Starlink is NOT in bypass mode
- Installed GS108T network switch
- Connected Starlink to the switch
- Orbi factory reset
- Connected Orbi to the network switch - success!
If I have issues with double NAT I'll try putting Starlink in bypass mode but, for now, since it's working I'm leaving it alone!
Cheers
Steve
- FURRYe38Oct 13, 2022Guru - Experienced User
Enjoy. 📡- stevesheadOct 13, 2022Guide
Sage advise! Thank you! 🙂
