poseidon7903
Dec 26, 2020Follower
Orbi RBR850 Wired Backhaul
To start, I'm not a huge fan of Netgear products. I've had horrible experience in their performance and support. That said, I've done research and in my search for a great WiFi 6 setup, the Orbi RB...
Dec 28, 2020Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
poseidon7903 wrote:To start, I'm not a huge fan of Netgear products. I've had horrible experience in their performance and support. That said, I've done research and in my search for a great WiFi 6 setup, the Orbi RBR850 kept coming up, so I decided to try it. I've now spent 48 hours trying to get this system to work the way it should. And I'm only just now getting there. AT&T definitely didn't help in this process as using their gig modem requires enabling DMZPlus. Not the easiest thing to find when you have no idea it's necessary. I'm coming from a Google Wifi Setup which was flawless. I do have a pretty heavily utilized Wireless network with near 100 devices connected. In my setup of the system, I've got both of my satellites connected and sync'd, but even though they have a network cable connected running to an unmanaged switch which then connects to the router which then connects to the pace modem, it only shows a 5ghz connection in the app and in the web portal. Shouldn't this say "Wired"? Is there something I need to do to get them to be recognized as a wired backhaul?
