DalekSupreme
Jun 26, 2022Aspirant
Orbi RBR850 wired satellite connection not recognised
I have had enormous problems with the RBR 850 since purchase. The latest issue is how the mesh keeps dropping the connection. So I have used an ethernet connection back to the router from a satellite...
Jun 27, 2022Guru - Experienced User
Whats telling you its disconnected? the gui through the browser? The app?
Does it work if you hardwire into the satellite?
You put its dropping connection? What exactly is happening? Is it saying "connected, no internet", is the wifi not broadcasting at all? Details are key.
What firmware is the router on?
What firmware is the satellites on?
what modem/gateway is it connected to?
