r38305
Aug 28, 2022Tutor
Orbi RBR850 wireless settings with Nest gen 3 thermostat
I've read several threads on this topic, but no cut and dry solution. My NEST app shows my thermostat intermittently disconnected. NG is escalating my call to second level, but so far no luck with ...
Aug 28, 2022Guru - Experienced User
Is your nest powered off the "c" wire? or a 4 wire to 5 wire powered setup (using the power adapter)?
I've seen reports of the nests that run using the standard wiring with a battery having frequent drops but that being resolved once the nest is powered full time.
