r38305
Aug 27, 2022Tutor
Orbi RBR850 wireless settings with Nest gen 3 thermostat
I've read several threads on this topic, but no cut and dry solution. My NEST app shows my thermostat intermittently disconnected. NG is escalating my call to second level, but so far no luck with ...
Aug 28, 2022Guru - Experienced User
You put you disabled wifi from the isp router. That doesn't disable its routing functions. Is the netgear in access point mode? or its address put in the isp's DMZ? (otherwise you're in a double nat)
r38305
Aug 28, 2022Tutor
I'm in router mode not AP mode. My disabled wifi on the ISP router/modem has bridge mode enabled.
- r38305Aug 28, 2022Tutor
It's looking like I've been able to isolate the problem to the ISP router/modem. Upon removing the Orbi I'm having the same NEST disconnect issues running off the ISP wi-fi. I'm either going to have to adjust the settings in the ISP gateway or get a new modem.
I'm surprised I can't bypass the ISP issues on bridge mode.
Any suggestions for a compatible modem with the Orbi RBR850? Or, any suggestions why my ISP router/modem is creating this issue? It is an Arris DG9450
- plemansAug 28, 2022Guru - Experienced User
Not sure why it'd be causing it. Do you get drops on the modem side of it?
