mrymk
Mar 25, 2021Tutor
Orbi RBR850 with Centurylink Fiber
Hello Everyone, I have a question. I am changing my Dads router to the Orbi RBR850 with Centrylink. Previous the router was at my house where I had no problems, only diff is that I have Xfinity. ...
- Mar 27, 2021
Thanks for letting us know. Please mark your thead and solved so others will know.
Enjoy. :smileywink:
Mar 25, 2021Guru - Experienced User
I would also ensure your using good quality LAN cables. CAT6 is recommended.
What is the Mfr and model# of the ONT the RBR is connected too?
Does using DHCP instead of PPPoE result in any difference?
Try powering OFF both RBR and ONT for 30 seconds then back ON.
I would contact the ISP and ask for help and information on this. Possible that PPPOE may not be needed.
