Lele855
Mar 24, 2022Guide
ORBI RBR850 with ILIAD operator in ITALY - ILIAD BOX
Hi Guys, i'm trying to find someone that activated in Italy the new fiber offer with ILIAD. I live in Milan and today Open Fiber installed me the ONT and ILIAD BOX. I've already connected my ORB...
Mar 24, 2022Guru - Experienced User
What actual model gateway is it?
I tried to look up some iliad boxes but everything was in italian.
Sorry. Not very good at reading them. 🙂
If its working well, you could be alright. Some gateways/setups tolerate double nat's better than others.
Lele855
Mar 25, 2022Guide
Hi plemans,
Thank you for your reply!
Sorry, maybe I don’t know the answer.. the firmare is 4.5.5-pre3 and since the installation seems to be all ok, the plus now is I can reach the gateway because also it is under the same network.. I activate also dmz for my RBR..
