Garden235
Jul 04, 2021Aspirant
Orbi RBR850 Won’t stay connected to internet
I have been using this RBR850 Orbi mesh router with 1 satellite in my 2500 sq ft home for the past year. It has worked flawlessly. In the last week it has begun to drop the internet connection multipl...
Mikey94025
Jul 05, 2021Hero
Garden235 wrote:
Disabled the Philip’s hue bridge in the devices connected to the router and it has been stable all day. Turned it back on in the Orbi app and internet disconnected almost immediately. Disabled and rebooted the router and the Orbi is running normally again. Seems to be an issue with the hue bridge.
How interesting. I have a Philips Hue bridge with my RBK850 system but have not experienced any of the disconnects you descrbe. Very good debugging!
Is it possible that the Philps Hue device is having an IP conflict or something with another device? I suggest trying to reset it, erase any DHCP reservation, and then reconnect it back to your home network. It might solve the issue. The other thing is to check if there is any device now using the same IP address as what your Philips Hue bridge was previously using.
Garden235
Jul 05, 2021Aspirant
I was wrong. Even with Hugh disconnected I am
Back to no internet every ten minutes or so. Tried factory reset one more time with no luck. About to spend $600 on a new mesh system but am hoping for a few ideas to fix this one before I do. The thing will not stay on the internet. All devices remain connected to network, just no internet.
