mrbobcc
Jun 05, 2023Aspirant
ORBI RBR850
Forgot pass word for my router . Try everything except factory reset. My question if I do a reset will my ADT, Liftmaster garage door opener, Hunter windows shades hub and gateway auto connect afte...
CrimpOn
Jun 05, 2023Guru - Experienced User
If the system is configured with exactly the same WiFi credentials (SSID/password), then every WiFi device will recognize and connect to it. I have done this when changing WiFi routers for nearly 20 years. Use the same WiFi credentials every time I change.
