sree23
Aug 21, 2023Follower
Orbi RBR850
Router is not getting connected to internet. it shows Pink light. It has been working for last 2 years and today started not working
Aug 21, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
PINK usually means that the RBR stopped getting data from the ISP modem or ONT:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
