bobberGman
Sep 06, 2021Follower
Orbi RBR850mesh network with ATT BWG210 -700 modem - need to be on one network.
Hi everyone, I'm using an ATT BWG210-700 modem / router and connected an Orbi RBR850 router with one RBS850 satellite. The problem is that my wired connections to the ATT router through a switch ...
Sep 06, 2021Guru - Experienced User
Its because you're in a double nat.
What is Double NAT? | Answer | NETGEAR Support
try putting the orbi in access point mode.
Tends to be the easiest router if you're planning on using both routers.
there are other options like disabling router mode on the ATT router or putting the netgear's IP address into the ATT's dmz.
