SDshaun
Dec 09, 2020Aspirant
Orbi RBR853 Satellites show disconnected but are working over Wifi.
Satellites are hard wired over CAT6. Been working okay but noticed connection issues with devices connected to the satellites yesterday. The network showed the satellites as all being disconnect. Reb...
Dec 09, 2020Guru - Experienced User
Are you seeing this on the Orbi app or on the RBRs web page?
When you connected the RBS to the RBR, did you first sync them to the RBR wirelessly, THEN after they were sync'd, connect them via ethernet?
Is there a ethernet switch in the configuration between the RBS and RBR?
- SDshaunDec 09, 2020Aspirant
Hi thanks for the questions, and answers below.
Cox and the Arris CM820
Currently both
Yes, I did do that, had them working wireless for a couple days when I first installed them before hardwiring them.
There is, its Dlink 24 port and one of the satilittes first hits a Dlink 8 port then to the same 24 port. (I just power off and on the 24 port just for fun but didn't see a change.)
- FURRYe38Dec 09, 2020Guru - Experienced User
What are the model #s of these switches.
What happens if you take both RBS to the same room or near the RBR and with a ethernet cable, connect them behind the RBR directly?- SDshaunDec 16, 2020Aspirant
The main switch is the Dlink DGS-1024D
Checking to see the route the satellites takes to get to the router. I think since goes directly to the DGS-1024D and the other hits a 8 port switch but will confirm.
Either way I disconnected one of them and moved it closer and when I plugged it back in, it connected perfect via wireless. The other still shows disconnected.
