AJW3208
Mar 29, 2026Follower
orbi rbr860 firmware 7.2.8.5 img file is missing from Dec 2025 security release update file
I am running a 3 node orbi system. (rtr + 2 x satellites). The solution is running 7.2.8.2_5.1.18. I am actually struggling with domain.local issues, but in looking for a fix, I noted a security ...
Mar 30, 2026Guru - Experienced User
The RBR860 FW file is present with in the .zip file for the RBR860:
https://www.netgear.com/support/product/rbk862
FURRYe38 wrote:The RBR860 FW file is present with in the .zip file for the RBR860:
Yes of course - and that has a .chk file extension - not the .img file extension that AJW3208 was expecting.
Looking at the thread, I believe the error message was the result of trying to install the RBR (router) firmware on the RBS (satellites).
