VeryCB
Jul 28, 2024Aspirant
Orbi RBR860 Speedtest at 3600+ Mbps but devices connected to 5Ghz only got ~900 Mbps
I'm on a hyperfiber 4 Gbps plan from my broadband provider and using RBR860 as the router, directly connected to the fibrebox via the 10 Gbps port. Then I tested the internet speed with Orbi app (...
- Jul 28, 2024
WiFi speed is a complicated subject. Internet search will provide reasons why a WiFi6 device will have a maximum theoretical Link Rate of 1200Mbps assuming that a two antenna device is using the full 80MHz wide channel.
Real world experience is always lower than the theoretical maximum:
https://www.reddit.com/r/HomeNetworking/comments/114622t/realworld_speeds_from_wifi6_aps/?rdt=35870
donawalt
Jul 28, 2024Hero - Experienced User
I have an iPhone 15 Pro and the Orbi 960. I get up to around 1400-1500 Mbps D/L with it.
If your iPhone is getting around 900, that suspiciously looks like the iPhone is using WiFi 5, not 6. I have seen the phone get stuck like that, and sometimes needs WiFi turned off/on, or even a restart.
If you use the Orbi app, run it on your phone, tap Device Manager, find your phone in the list, and tap the name - you will see something like this. Is it on 6 GHz?
Also - how far away from the router are you when you run the WiFi speed test?
And, what version of firmware are you running on the 860?
CrimpOn
Jul 28, 2024Guru - Experienced User
The Orbi 860 is a WiFi6 product. Orbi 960 is WiFi6E.
That may explain some of the observed difference in performance.
Cisco had this to say about WiFi6 vs. WiFi6E
https://www.cisco.com/c/en/us/products/wireless/what-is-wifi-6-vs-wifi-6e.html
The attached image shows the device connected to WiFi6E (6GHz). I would not be surprised for it to have higher performance, although a Link Rate of 6Mbps is the lowest possible Link Rate.
- donawaltJul 28, 2024Hero - Experienced User
CrimpOn yes but Wifi 6 does faster than 1G - that's why I suspected the phone may be connected to 5 GHz - I see it all the time here, and with my Mac also. Whether it's an Apple or NG problem, no idea. But frequently it requires a WiFi toggle off/on or device restart. 900 Mbps looks suspiciously like the ceiling for 5 GHz.
- CrimpOnJul 28, 2024Guru - Experienced User
The Orbi 860 specs say it does not include a 6GHz radio.
https://www.downloads.netgear.com/files/GDC/RBR860S/RBR860S_TS.pdf
So, yes. The iPhone 15 Pro is definitely connected to the user facing 5G WiFi of the Orbi 860.
CrimpOn wow! And yet at the top it's called a WiFi 6 Router! Yet I see where the radios are WiFi 5!
Look here - https://www.netgear.com/home/wifi/mesh/rbr860s/
It says this - what's going on? But if it's truly 5 GHz there's your answer - that's 920Mbps or so max d/l speed.
