JJG1992
Jan 02, 2026Apprentice
Orbi RBR863 reboots, connection drops after recent firmware releases
The only firmware versions that work with my Orbi are V7.2.6.31_5.0.24 and previous versions. The latest firmware versions result in slow download speeds, random dropouts/disconnects, and reboots. I ...
Jan 03, 2026Guru - Experienced User
So v7.2.8.5 FW is causing issues?
What connection is dropping? WiFI Clients or ISP service?
What Brand and model# ISP modem/ONT do you have?
What channels are you using on the RBR?
Distance in between the RBR and RBS?
Size of home in sq feet please.
There is known issues with IPv6 on FW versions past v.31. Was recommended to disable ALL IPv6 protocols on systems running FW versions past v.31.
I have had my 960 series on line with v7.8.2.5 and is stable and solid. However I don't have natvie IPv6 support from the ISP so it's disabled for me.
Something to try on your 860 series with v.5 FW loaded.
My systems are manually loaded, power cycled, factory reset and setup from scratch for a good clean FW update and system setup.
