JHRucker
Aug 18, 2022Aspirant
Orbi RBRE 960 drops WiFi clients several times a day
I recently installed a Orbi WiFi 6 RBRE960 router with two satellites. Both the satellites are connected over hardware backhaul. WiFi clients connected to both satellites randomly are dropped throug...
- Aug 29, 2022
Update. I was able to get the connection between the Satellites and Router to be stable by switching from a hardwired backhaul to wireless backhaul. It is about 90% more stable now but still has a few issues. My "far away" satellite works great when it shows it is connected to the "not so far away" satellite for its connection. But randomly the "far away" satellite will connect directly to the router and it shows a poor backhaul status. I have no clue why it does this, there are no power outages or anything that I can tell would cause the backhaul connection to change.
Anyone else seeing this? I think I will post this as a new issue.
Aug 18, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is the separate 6Ghz and IoT SSID broadcast enabled or disabled?
What devices do you have connected?
Are the RBS directly connected to the back of the RBR or is there a LAN switch in between.
What is the brand and model# of the switch being used?
Are you using he 2.5Gb LAN ports or the 1Gb LAN ports to connect the RBS to the RBR?
What CAT# lan cable are you using?
JHRucker
Aug 19, 2022Aspirant
Thanks for the reply.
I don't think my issue is a signal strength problem. Wireless devices show full signal strength. They just loose connection. When I look at the iPad's WiFi setting (during the disconnect) the WiFi SSID is completely gone from the list. After a few moments it reappears and connects and works fine. What's a bit concerning is in addition to my SSID reappearing, I also see the NetGear's default IOT and Guest SSIDs appear in the available WiFi networks. The are there for a minute or two and disappear. I do not have those enabled! It almost appears as if the orbit satellite is rebooting or something??
My two satellites and router 2.4g ports, are plugged into a switch.
We live in a very rural setting no other WiFi hubs around.
- FURRYe38Aug 19, 2022Guru - Experienced User
Will be good to give feedback to the questions presented please so we can better help you out.
