sfgtsfn
May 24, 2023Aspirant
Orbi RBRE 960 shows out of sync with satellite, even though i have devices connected to satellite
could not get sync to work, however I did get blue light and devices are connecting to satellite. just shows OOS and everytime I try to resync is says attempt failed. both devices have same firmwar...
May 25, 2023Guru - Experienced User
What browser are you using?
How are you resetting the system? Are you resetting and setting up from scratch both on the RBS and RBR?
- sfgtsfnMay 25, 2023Aspirant
chrome, v6.3.7.10, I have reset both and started from scratch. xfinity internet CGM4981COM is modem
- FURRYe38May 25, 2023Guru - Experienced User
How are you setting up the system after a FR? Web browser and setup wizard, adding RBS using the RBRs Add Satellite option or Orbi app?
Do you see a Generation Backhaul Password button under Advanced tab/Advanced/Wireless settings on the RBRs web page?
I have set it up via router interface and the Orbi app. I do have a Generate button
