Kielty's avatar
Kielty
Star
May 21, 2023
Orbi RBRE 960 Wifi Speed
Really happy with the RBRE960 System I have just purchased. Router and 2 satellites.   When running a speed test with my MacBook Pro 2x2 I get approx 500 Mbps. The TX rate is 1200 and the PHY 802AX...
  • plemans's avatar
    May 21, 2023
    You can try swapping channels to see if it helps.
    But it might not. Usually you get around 55-65% of the link speed for throughput. You're a bit below that but it could be related to the PC, network overhead, etc.
    What speeds do you get wired?
