Rickp703
Oct 06, 2022Aspirant
Orbi RBRE950 Loses Internet connection almost every Thursday randomly (and not an ISP issue)
Hello, I have a RBRE950 router (Costco version of RBRE960) with 4 Satellites (all RBSE950's). It seems every week (on Thursdays) the router loses an Internet connection. I'm hoping there ...
Oct 06, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Do you have the IoT and Separate 6Ghz radios enabled?
