senadaruc
Feb 29, 2024Aspirant
Orbi RBRE960 10GB internet port speed issues!
Hello, I have a 10GB router connected with CAT8 Cable into my Orbi RBRE960 10GB internet port on AP mode. Unfortunately, I can't see more than 5GBPS down and 3GBPS upload speed. ...
Feb 29, 2024Guru - Experienced User
What is the Mfr and model# of the host router the NG router is connected too?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Speed testing wired or wireless?
What are the connection rates seen with your test device connected to the RBRs LAN ports?
There's only 1x 2.5Gb LAN port so this will max out here. The other LAN ports are all 1Gb so they will be maxed out here as well.
- senadarucFeb 29, 2024Aspirant
Thanks for the replay, and Firmware Version V7.2.6.21_5.0.20, I can confirm that on the router directly, I see 8GBPS using my laptop and 10GBPS network card.
Testing is done on the webgui of the Orbi, on the 2.5GB port i can reach the 2.5GB speed.
S,
