pvanbeek
Aug 21, 2023Aspirant
Orbi RBRE960 as AP behind Firewalla Purple
Previously configuration was a Spectrum Modem connected to a Firewalla Purple (FWP) in router mode connected to an Orbi Mesh system in AP mode. Everything worked flawlessly. I wanted to upgrade to ...
CrimpOn
Aug 21, 2023Guru - Experienced User
Can you confirm that although WiFi is intermittent, that wired devices are stable?
The correct implementation is to "copy what worked" exactly. i.e.
- Firewalla connects to modem with Ethernet cable
- Orbi router (RBRE960) WAN port connects directly to Firewalla LAN port with Ethernet cable. (no switch in between)
- Orbi satellites connect to the router either
- Using the default 5G WiFi backhaul, or
- Using Ethernet connection to the RBRE960 LAN ports (either directly or through a switch)
It might be useful to take it "one step at a time." i.e.
- Connect only the router and see if connections are stable before adding satellites.
- Depending on what the original Orbi system was, the Guest and other WiFi SSIDs may behave differently with the 960 product than before. If the previous system was the original "50" product, for example:
- Guest devices get assigned IPs in a different IP subnet with the 960
- There is no option about Guest devices having access to the primary network as with the 50 router.
