pvanbeek
Aug 21, 2023Aspirant
Orbi RBRE960 as AP behind Firewalla Purple
Previously configuration was a Spectrum Modem connected to a Firewalla Purple (FWP) in router mode connected to an Orbi Mesh system in AP mode. Everything worked flawlessly. I wanted to upgrade to ...
pvanbeek
CrimpOn - thanks for the quick reply and good callouts.
I did connect exactly as before (Orbi RBR50v2) and had the issue I described below. I also took it slowly and only had the RBRE960 connected to the Firewalla.
Wired clients maintained connectivity.
Orbi Satellite backhaul connection to the RBRE was wireless.
I knew the RBRE960 handles guest networks differently than the RBR50, so guest network and IoT are OFF.
Connectivity is still "bouncing" every 30-45 seconds.
Phil
Aug 21, 2023Guru - Experienced User
Does this happen if router mode on the RBR and does this happen with the RBR if the Firewalla device is NOT in the configuration, just connect the RBR to the ISP modem in router mode and see if the problem continues?
What channel configurations are currently set on the router?
What other devices are near by the RBR?
How many RBS are deployed?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
- pvanbeekAug 21, 2023Aspirant
No, this does not happen if the RBRE960 is in router mode and the Firewalla is removed from the configuration.
Channel Configurations are 2.4 (Auto), 5 (40 GHz) and 6 (69 GHz)
No other wireless devices near the RBRE960, and again, when in Router mode, the Orbi works FLAWLESSLY
No wireless interference from neighbors - we are on acreage with no homes nearby.
1 RBS is deployed
House is 3000 SF - RBRE on 1st floor and RBS on 2nd floor about 60 feet away - but have unplugged the RBS with same results
RBRE960 Firmware is V6.3.7.10
Spectrum Modem is Arris TM1602
All Cat6 cables
- FURRYe38Aug 21, 2023Guru - Experienced User
Sounds like something in the firewalla device maybe causing problems though you wouldn't think so if the RBR is in AP mode and just passing data thru. However have seen other users with similar firewall appliance device causing problem, blocking too much traffic or blocking some traffic that the Orbi system relies on. Once this is resolved at the firewall device, Orbi started working correctly.
- pvanbeekAug 22, 2023Aspirant
I am happy to report that in the last 14-16 hours, the intermittent WiFi issues have stopped...and I have no idea why. It almost seems like it needed to "soak" for a bit.
I appreciate the quick replies and suggestions to try to remedy the issue.
Thank you!
Phil
