MS_1234
Jun 25, 2022Guide
Orbi RBRE960 constantly disconnects/connected with out internet
We’re you ever able to resolve this issue? I have the same exact problem. The outages are not limited to just Sonos- if affects everything from Chanberlain garage door openers, iDevices switches, euf...
Jun 26, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
For Apple devices, review this:
MS_1234 wrote:
We’re you ever able to resolve this issue? I have the same exact problem. The outages are not limited to just Sonos- if affects everything from Chanberlain garage door openers, iDevices switches, eufy cameras, etc.
- MS_1234Jun 26, 2022Guide
Thank you for your help! Here are the answers to your questions:
V6.0.3.85 is on the RBR and both RBS
Verizon FIOS ONT model number I-211M-L
About 3600 sq ft.
I am using a wired backhaul
The RBR is in the basement
The first floor RBS is about 15 feet horizontal distance plus about 5’ vertical distance from the basement RBR
The second floor RBS is about 20 feet horizontal distance plus about 10’ vertical distance from the first floor RBS
The house is typical residential construction. Sheetrock over wood studs.
2.4 GHz is auto
5 GHz is channel 48
6 GHz is channel 69
Yes. Occasionally I can see my neighbors WiFi. I have two neighbors, but rarely see the second neighbor’s signal. Seeing either neighbor’s WiFi signal depends upon where I am in my house, and it’s not a very good signal when I do see it
- FURRYe38Jun 26, 2022Guru - Experienced User
Does the front LED on the RBR turn on RED when this happens?
About 3600 sq ft.
For this size of home, you really only need the RBR and 1 RBS. Having too much signal in the home can be problematic.
The RBR is in the basement< Basements are not recommended placed for the RBR. Concrete and steel impacts wifi signal travel. RBR should be on main/1st level or a 2nd level.
Distances between the RBR and RBS to too close. 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using?
2.4 GHz is auto
5 GHz is channel 48
6 GHz is channel 69
Might try channel 1 and 40. 69 is Ok.
- FURRYe38Jun 29, 2022Guru - Experienced User
Any progress on this?
About 3600 sq ft.
2.4 GHz is auto
5 GHz is channel 48
6 GHz is channel 69
- MS_1234Jun 30, 2022Guide
No progress, no solution yet. So far I have tried:
1) I disconnected both the RBS from the wired backhaul, spaced them apart from each other by approximately 40 feet, and I am using wireless backhaul. The devices are not closer than 20 to 30' from another wireless device. The Orbi's report the wireless backhaul is "good".
2) I disconnected all wired devices from the ethernet ports on the RBS.
3) I moved all IoT WiFi devices to the -IoT wifi network
I still routinely experience WiFi devices dropping from WiFi. Both the regular WiFi network and the -IoT WiFi network drop. These drops happen several times per day.
Some devices, like the Eufy cameras, will disconnect, and then reconnect in a few minutes (I know this because I get the warning that the cameras are offline in HomeKit).
Other devices like the Chamberlain garage door smart hub will disconnect and will never reconnect. (I need to power cycle these for them to reconnect)
Any suggestions?
