MS_1234
Jun 25, 2022Guide
Orbi RBRE960 constantly disconnects/connected with out internet
We’re you ever able to resolve this issue? I have the same exact problem. The outages are not limited to just Sonos- if affects everything from Chanberlain garage door openers, iDevices switches, euf...
Mikey94025
Jun 25, 2022Hero
MS_1234 wrote:
We’re you ever able to resolve this issue? I have the same exact problem. The outages are not limited to just Sonos- if affects everything from Chanberlain garage door openers, iDevices switches, eufy cameras, etc.
I haven't had any "No Internet" problems with my Liftmaster garage door opener, iDevices switch, or Nest 24/7 cameras connected to my RBKE963 system. I have changed CTS/RTS Threshold to 2347 for 2.4Ghz.
I also disabled the "6 GHz Only Network" since I have no 6E-compatible devices and read in other posts that leaving this enabled has caused problems for some AXE system customers. You might also try making that settings change to see if it helps you any.
Jun 26, 2022Guru - Experienced User
You are aware that 6Ghz is still broadcasting on the main WLAN radio right that separate from the 6Ghz SSID section?
- Mikey94025Jun 26, 2022Hero
FURRYe38 wrote:You are aware that 6Ghz is still broadcasting on the main WLAN radio right that separate from the 6Ghz SSID section?
I don't understand, can you explain in more detail? If I uncheck "Enable 6 GHz Only Network" isn't the 6 Ghz SSID disabled? What else is still running on 6 Ghz and what is it used for?
Thanks.
- FURRYe38Jun 26, 2022Guru - Experienced User
Been told that the separate 6Ghz SSID is to let users ensure that there 6Ghz devices connect specifically to the 6Ghz radio only.
There is a 6Ghz signal being broadcast along with the 2.4 and 5Ghz signal on the main WLAN.If you disable the separate 6Ghz signal on the RBR and connect a 6Ghz device to the main WLAN, it will connect to the 6Ghz signal while that separate 6Ghz radio is disabled.
This is my PC using Intel AX210 adapter connected to the 960s main WLAN with the separate 6Ghz radio disabled:
