MS_1234
Jun 25, 2022Guide
Orbi RBRE960 constantly disconnects/connected with out internet
We’re you ever able to resolve this issue? I have the same exact problem. The outages are not limited to just Sonos- if affects everything from Chanberlain garage door openers, iDevices switches, euf...
DwayneW
Dec 18, 2022Guide
While I don’t have the 960 such as yourself. I do have the 850.
It has similar issues where it loses the internet, can’t get DHCP address.
At one time back in Oct when this happened it was after a firmware update that changed my rts/cts from 2347 to 64, once I change it back my Wi-Fi mesh was all happy once again.
Then last week happened…Same issue, some devices can connect via Wi-Fi, others can’t. I did not pay attention to what they may have in common.
But in trouble shooting by enabling my guest network, my iPhone was able to connect, get a dhcp address and life was good, but why do I need to do this?
So process of elimination lead me down the path of maybe it is another device conflicting with Orbi DHCP?
After unplugging one by one and testing theory, something was/is messing with Orbi Mesh DHCP and yet for reasons I can’t explain.
Remove the POWER from the Chamberlin myQ device. My guess is all your issues may be solved, after you reboot them so they may get back the DHCP reservation.
It has been a week, my network is happy and I do miss myQ, yesterday I plugged in myQ again and my devices started losing IP reservations again.
Hope this helps you and others.
