PV23QLD
Sep 18, 2022Tutor
Orbi RBRE960 constantly dropping wifi to iPhone?
I recently purchased Netgears Orbi RBRE960 units thinking they were a great product. Unfortunately the reviews I’ve read recently tell a difference story. Seems they still can’t get the wifi drop outs...
- Sep 20, 2022
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? - ZTE ZXHN H268AYour ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopBe sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. - yes cat 6 connected
What Iphone and iOS are you using? - 15.6.1
What is the size of your home? Sq Ft? - 215 sq meters
What is the distance between the router and about 10 meters - 30 feet.Please turn off 1 RBS if you have two deployed. You may have too much wifi signal for that size of home.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. I will try setting manual channel 1 for 2.4Ghz and 40 for 5Ghz and 69 for 6Ghz.
Any Wifi Neighbors near by? If so, how many? - 6 neighbors <What channels are they using?Do you have the IoT and separate 6Ghz radios enabled on the RBR? - yes both enabled. <Are you using the IoT broadcast?
Please DISABLE the separate 6Ghz SSID broadcast.
Sep 18, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Can't say I've seen any issues with my iPhone here. 12 Pro max iOS 16.
PV23QLD wrote:
I recently purchased Netgears Orbi RBRE960 units thinking they were a great product. Unfortunately the reviews I’ve read recently tell a difference story. Seems they still can’t get the wifi drop outs sorted when using apple products. I have Apple iPhones and other devices monitored by iPhones and constantly getting wifi drop outs. Doesn’t matter what time of day, wheee I am in relation to distances from satellites.
Has anyone had similar issues and managed to find a solution. The Netgear technical support line don’t have any answers either.
Thank you.
PV23QLD
Sep 19, 2022Tutor
Hi FURRYe38,
What Firmware version is currently loaded? - V6.5.3.2
Thank you
- FURRYe38Sep 19, 2022Guru - Experienced User
PV23QLD wrote:
Hi FURRYe38,
Couple of options,
- TC_in_MontanaSep 19, 2022Virtuoso
PV23QLD wrote:
Hi FURRYe38,
PV23QLD Curious as to how/where you got firmware version 6.5.3.2. The latest posted version is 6.3.0.85 and there was another version online temporarily then pulled (I think it was 6.3.1.21?). Or is the firmware version a mistype?
Just curious.
- PV23QLDSep 20, 2022TutorHi,
I accessed my Orbi account and went to about and that’s what the FM version showed attached.
Could this be an issue ?
Thank you- FURRYe38Sep 20, 2022Guru - Experienced User
Couple of options,
