PV23QLD
Sep 18, 2022Tutor
Orbi RBRE960 constantly dropping wifi to iPhone?
I recently purchased Netgears Orbi RBRE960 units thinking they were a great product. Unfortunately the reviews I’ve read recently tell a difference story. Seems they still can’t get the wifi drop outs...
- Sep 20, 2022
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? - ZTE ZXHN H268AYour ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopBe sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. - yes cat 6 connected
What Iphone and iOS are you using? - 15.6.1
What is the size of your home? Sq Ft? - 215 sq meters
What is the distance between the router and about 10 meters - 30 feet.Please turn off 1 RBS if you have two deployed. You may have too much wifi signal for that size of home.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. I will try setting manual channel 1 for 2.4Ghz and 40 for 5Ghz and 69 for 6Ghz.
Any Wifi Neighbors near by? If so, how many? - 6 neighbors <What channels are they using?Do you have the IoT and separate 6Ghz radios enabled on the RBR? - yes both enabled. <Are you using the IoT broadcast?
Please DISABLE the separate 6Ghz SSID broadcast.
michaelkenward
Sep 18, 2022Guru - Experienced User
Your subject says "Orbi RBRE960 constantly dropping wifi to iPhone?"
It might help to think of it the right away round.
It is more likely that the iPhone is losing the connection to the router.
Recent incarnations of the iPhone have implemented a "security" feature that has led to quite a few problems with wifi connections.
Try starting with this tip:
Re: NH6700 Router: Cannot access router directly o... - NETGEAR Communities
PV23QLD
Sep 19, 2022Tutor
Hi Michaelkenward,
Ive disabled the private wifi (MAC) address on my Iphone 11 Max Pro - version 15.6.1 and will see how that goes
Thank you
