Abu7waij
Oct 02, 2023Aspirant
Orbi rbre960 crashes when xbox one or series x connects to it
Orbi crashes and restarts every few minutes with xbox one scorpio or xbox series x connects to it. Tried setting Nat to open, firmware is latest, nothing is fixing it. Any suggestions please?
- Oct 17, 2023Yes. I connected the xbox to the orbi with ethernet cable. At that point finally orbi said that a new device was detected instead of crashing. After that WiFi connection works fine so far.
Oct 17, 2023Guru - Experienced User
Any progress on this?
- Abu7waijOct 17, 2023AspirantYes. I connected the xbox to the orbi with ethernet cable. At that point finally orbi said that a new device was detected instead of crashing. After that WiFi connection works fine so far.
- FURRYe38Oct 17, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
