Retired_Member
Jul 17, 2023Orbi RBRE960 DC Cable Extension?
Dear community, I have the new RBKE963 Orbi system. Now there is a power adapter DC (19V 3.16A). But since the cable is too short and an extension simply with a Schuko plug does not work structurally...
Jul 17, 2023Guru - Experienced User
Retired_Member
Jul 17, 2023Thanks, but I meant the other side, so the small dc plug. I am assuming it is something like 5,5mm x 3mm but not sure. I have to extend the cable not at the power supply side. I hope it is now clearer. Thanks
- FURRYe38Jul 17, 2023Guru - Experienced User
They don't.
The plug is a special type and size of plug. 7.7mm with no center pin. Easier to extend the power adapter side.
