novasbc
Dec 12, 2022Aspirant
ORBI RBRE960 IPv6 Firewall Settings
For the life of me, I can't figure out how to edit any IPv6 firewall settings. It seems to be set to filter all packets incoming (secure by default which is great) when you aren't using IPv6 passthr...
robdogaz
Jan 17, 2023Aspirant
How do I turn off firewall in general on this model? I have so many problems connecting to work VPN
- CrimpOnJan 17, 2023Guru - Experienced User
robdogaz wrote:
How do I turn off firewall in general on this model? I have so many problems connecting to work VPNSometimes adding another topic at the end of a post from a month ago does not attract attention. It is often more productive to begin a new conversation.
The only method for disabling the Orbi firewall is to put it into Access Point (AP) mode behind a different router. This removes all sorts of features, including the firewall. This only works if the Orbi is actually connected to a router, rather than a simple "modem."
It might help to describe the problem in more detail. In general, residential routers are not aware what devices are doing when they connect to the internet. They see a secured connection to some internet IP address, but they cannot "see into" any of the packets. There must be millions of people using various VPN services (Express VPN, NordVPN, etc. etc.) behind routers. I, myself, tested NordVPN with my Orbi. (meh. more trouble than it was worth.) For work, use of VPN is obviously a requirement. What do the IT folks at work say about your issues?
- robdogazJan 17, 2023Aspirant
Actually your response was very helpful and I fixed my issue.
