dsolson
Jun 15, 2024Aspirant
Orbi RBRE960 Router - RBSE960 Satellite connection
Can’t get a purchased used RBSE960 Satellite to connect to my Existing RBRE960 router. I did a 15 sec factory reset on satellite. Boots up fine but when I go through the sequence to add the satellite ...
- Jun 17, 2024
I setup my old rbr40 as an AP and have it Ethernet connected to the RBRE960 network. Works perfect. I think you mean I have to get another RBSE960. I’m not going to sink more money into it at this point. Thank you again.
dsolson
Is there a risk of doing a factory reset on my router? It is working so well.......
CrimpOn
Jun 15, 2024Guru - Experienced User
A Factory Reset erases the entire configuration. Anything that the user has configured no longer exists.
- administrative credentials
- WiFi credentials (if changed from the default printed on the product label)
- Any settings for DNS servers
- Reservations of IPs for specific devices
- the list goes on and on.
If you have done nothing to configure the system, then a Factory Reset has little effect (99.9% of the time).
- dsolsonJun 15, 2024AspirantOk thanks for all your help today. Kudos
