dsolson
Jun 15, 2024Aspirant
Orbi RBRE960 Router - RBSE960 Satellite connection
Can’t get a purchased used RBSE960 Satellite to connect to my Existing RBRE960 router. I did a 15 sec factory reset on satellite. Boots up fine but when I go through the sequence to add the satellite ...
- Jun 17, 2024
I setup my old rbr40 as an AP and have it Ethernet connected to the RBRE960 network. Works perfect. I think you mean I have to get another RBSE960. I’m not going to sink more money into it at this point. Thank you again.
dsolson
Is there a risk of doing a factory reset on my router? It is working so well.......
Jun 15, 2024Guru - Experienced User
No. I was hoping that would not be needed, however, might be last resort to try.
- dsolsonJun 16, 2024AspirantSo the satellite was magenta this morning when left in wireless overnight. I wired the rbse960 to a switch in the lower floor. It shows as a wired device (not satellite). My son’s iPhone shows as a wired connection DSO it must be wirelessly connected to the satellite. So kind of like it’s acting like an AP, Strange?
- dsolsonJun 16, 2024AspirantUnmanaged switch it is connected to btw
- FURRYe38Jun 16, 2024Guru - Experienced User
Brand and model of this switch?
CAT# lan cable being used?
Which ports on the RBS are you using to ethernet connect it to the switch?
Wondering if this RBS is just plain faulty...
- dsolsonJun 16, 2024AspirantSwitch is TP-Link TL- SG105 (gbit unmanaged 5 port switch)
Cat 6 Ethernet - I think some of my ethernet cables are Cat 5E from router to switch. Satellite Ethernet is one of the regular LAN (not the 2.5G). Router is regular LAN to switch. Of course yellow internet connection router to cable modem.
It looks like when connected by Ethernet, it shows as device and it broadcasts because devices connect wireless to it apparently. But wireless receiving doesn’t appear to work??? I think it has faulty wireless electronics. Wish I knew how to verify because I may have to make a case for refund on FB marketplace. - dsolsonJun 16, 2024Aspirant1G is fine as my service is only like 390 mbps at my house
Any chance to test the RBS directly connected to the back of the RBR? Want to rule out any problems coming from the switch. Or cabling.
If you got this used from FB market place, could be in any unknown condition.
Ok. Hooked up with new Ethernet cable. 6’ away. Std LAN ports both router and satellite. Shows as “wired” connected device (not satellite) with IP address assigned. I verified it is the satellite by MAC address.
FYI - prior to moving it up to hook directly to router, my son’s devices (iPhone and Xbox) had wirelessly connected to it when it was on the lower floor as it was close to his room. It was ethernet connected to that Tplink switch (that switch is actually a second one downstream from router). Those devices showed as “wired” as well. Must be because the satellite was wired?
So looks like the wireless connection to router doesn’t work but it will allow devices to connect to network when it is wired by Ethernet…..
thanks for your help once again!
- FURRYe38Jun 17, 2024Guru - Experienced User
Beginning to wonder if the Wireless BH is just broke on the RBS.
You'd need to find another RBS to test and see if the behavior changes.
- dsolsonJun 17, 2024Aspirant
- CrimpOnJun 17, 2024Guru - Experienced User
Just one minor technical note: Devices that are 'wired' to this RBR40 will indeed work perfectly. WiFi is a more nuanced situation.
- WiFi devices that connect to this RBR40 and are not mobile will be fine.
- WiFi devices that are mobile will not roam seamlessly between the primary 960 WiFi network and the RBR40 WiFi network. Even if both are set to identical WiFi credentials (SSID/password), they remain separate networks.
If the RBR40 has been placed in a location which had poor WiFi from the primary 960 system, you may observe that mobile devices struggle when moving around the house. They may cling stubbornly to whichever WiFi unit they first connect with, even as performance drops. They may switch from 5G to 2.4G connections. If the device turns WiFi off and back on again, it will switch to the stronger WiFi signal.
This issue is what caused 'mesh' WiFi systems to be created 8-10 years ago. Prior to that, users expanded WiFi coverage by deploying separate WiFi access points and were frustrated by this roaming issue.
Just something to be aware of.
Thats works good. Sorry RBS didn't work out.
Good Luck.
