dsolson's avatar
dsolson
Orbi RBRE960 Router - RBSE960 Satellite connection
Can’t get a purchased used RBSE960 Satellite to connect to my Existing RBRE960 router. I did a 15 sec factory reset on satellite. Boots up fine but when I go through the sequence to add the satellite ...
  • dsolson's avatar
    dsolson
    Jun 17, 2024
    I setup my old rbr40 as an AP and have it Ethernet connected to the RBRE960 network.  Works perfect.  I think you mean I have to get another RBSE960.   I’m not going to sink more money into it at this point.  Thank you again.
