jaberle
Apr 13, 2022Aspirant
orbi RBRE960 vpn and Webex issues
Recently upgraded from RBR50 and experiencing issues with Webex video calling I use most of the day. This issue did not happen with RBR50 set up. Currently on v6.0.3.85. The issues is that the audio ...
Apr 13, 2022Guru - Experienced User
did you try disabling sip alg and rebooting the router?
jaberle
thank you, the "Disable SIP ALG" was checked, I guess by default as I did not change this setting.
- KevinLiTApr 13, 2022NETGEAR Moderator
Hello jaberle ,
I understand that you are having issues with your RBRE960 when using Webex. Can you give more information on the issues you are experiencing with the VPN as well?
Look forward to hearing from you!
Best,
Kevin
Community Team
- jaberleApr 13, 2022Aspirant
After additional testing, it seems better when not using VPN while using Webex, but that does work for me, as I need to have VPN in to perform other work while webex is active. It was a thought that VPN might be causing the issue, just not sure. Again, that has not changed since moving to the new Router. With the RBR50 I had no issues with VPN active.
thanks!
- FURRYe38Apr 14, 2022Guru - Experienced User
What devices are you using that's connected to the system?
Is Armor or SPC enabled on the system?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteTry turning OFF the RBS and connect just to the RBR. Same thing still happens?
