fcwest
Mar 25, 2025Star
Orbi RBRE960E not renewing/releasing DHCP assigned by ISP - causing internet to go offline
Orbi:RBRE960E Firmware: V7.2.6.31_5.0.24 Previously, I was with Spectrum and their 1GB cable connection, which rarely had issues. 1 week ago, I switched to 2.5Gbps fiber connection with a new IS...
- Mar 25, 2025
Does the front LED on the RBR turn PINK when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.v.31 had problems reported from posters. I recommend updating to more newer code: https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/New-Orbi-RBR-RBS-850-860-and-960-series-Firmware-Version-7-2-7/td-p/2435724
If you do update, I highly recommend doing a power OFF of the Orbi system and your ISP modem/ONT for 1 minute then back ON.
I would get with the ISP and ask them if there seeing any interruptions on the ISP Modem/ONT during these time frames to help see if they can stop these interruptions from there side.
Mar 25, 2025Guru - Experienced User
fcwest
Mar 27, 2025Star
Updating to the latest firmware resolved the DHCP release issue. I'm good to go. Thank you!
- FURRYe38Mar 27, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
