veranah
May 11, 2022Follower
Orbi RBR/RBS 850 - Firmware upgrade sequencing
Hi All,
Are RBR/S850 firmware upgrades cumulative or serial from oldest to newest?
My concern has been raised by a cautionary advisory note that states that you cannot rollback from an upgrade.
Regards
Veranah
1 Reply
One of the firmwares, they don't recommend rolling back from because it can potentially brick your device.
but usually you can rollback without concern.
They're cumulative and should contain the prior version's fixes as well as the current releases.
