airgrunt82
Sep 08, 2023Follower
Orbi RBS 750 dropping speeds
I have an Orbi ax 4200 triband mesh wifi 6 system, main router and two satelites. I have Windstream Kinetic gig service. I have had this Orbi for 18 months, over the last 3 months it has been droppin...
Sep 08, 2023Guru - Experienced User
Instead of using Orbi app, what speeds do you see with a ethernet connected PC and wireless device using Ooklas installable speed test app?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
