MNChuck
Dec 13, 2022Tutor
Orbi RBS 750 satellite disconnecting - wired and on latest firmware
I have an Orbi RBK 750 with 2 satellites and did the manual update to the latest firmware (4.6.14.3_2.3.12) last week followed by a power cycle of the entire system. Satellites are both wired backha...
- Dec 13, 2022
Modem in Netgear CM1150 - it is connected to the internet feed into the home and output is to the Orbi Router. Pretty sure wiring is not the issue as this system has worked well for some months now without issues.
I did another power cycle of the entire system and now both satellites show as connected. All devices that should be on the network are showing on the 'attached devices' page.
Dec 13, 2022Guru - Experienced User
How do you have the wired backhaul setup?
And what modem/gateway is it going to.
I've seen them wired improperly.
It should go
gateway--->wan port on router---->lan ports to switch/satellites.
MNChuck
Dec 13, 2022Tutor
