Beantowm111
Feb 27, 2023Apprentice
Orbi RBS 850 Satellite with RBR 960
The Ethernet ports on my RBR 850 (Router) stopped working over the weekend, and despite many attempts (update firmware, factory reset), nothing has fixed them (wifi works for a while but eventually a...
Feb 27, 2023Guru - Experienced User
NG hasn't officially said either way they are or not supporting 7 or 8 series RBS connecting with the 9 series.
I can say that I tested one of my 8 series connected wirelessly to my 9 series and it works fine. I think someone tested a 7 series too. So I would presume from a simple use case, go for it if you need. Should something happen though that would cause a support phone call, be prepared for "That's not supported" kind of response during troubleshooting with NG.
Beantowm111
Thanks!
- FURRYe38Feb 27, 2023Guru - Experienced User
đ
