duduteo
Nov 04, 2022Aspirant
Orbi RBS350 Continously Blinks White and Solid magenta
I just got this RBS350 wifi 6 system with 2 satellite , however one the first few days everything work perfect. Then one of the satellite further away from router getting 2.4ghz. i shift my router...
ekhalil
Nov 11, 2022Master
Do you have the latest firmware Version 4.4.1.29 in the router and satellites?
duduteo
Nov 11, 2022Aspirant
Thank for replying, I already have the latest firmware Version 4.4.1.29 in the router and satellites however it still connection issue. I already give up on Orbi , exchange to Asus XT8 which double up my download and upload and perfect connection at the same location i place my router and satelites. Fully not recommended Orbi to anyone if they looking for a mesh system .
- ekhalilNov 11, 2022Master
Good luck with your new mesh system.
In fact I have 3 satellites RBS350 connected to an RBR850 and all is working just fine.
You maybe just happened to have bad luck with Orbi, or -likely- your network had some issues.
