mikeymikemik3
Feb 17, 2022Tutor
Orbi RBS350 Continously Blinks White
After moving locations, one of my satellites stopped working and the Orbi app is unable to identify it. I already tried doing a hard reset and its just continously blinks white. The firmware versio...
- Feb 17, 2022
Is 3 meters enough distance? I've pressed on the sync button and its blinking white for quite a long time now
Feb 17, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Does the RBS appear in the RBRs web page at all?
- mikeymikemik3Feb 17, 2022Tutor
I literally placed the satellite almost right next to the router. The RBS does NOT appear in the RBRs web page at all.
- FURRYe38Feb 17, 2022Guru - Experienced User
Try at least 10 feet away from the RBR. Next to the RBR is too close.
Is a prior RBS entry on the RBRs web page exist or nothing is seen here?
Press the sync button on the RBS then on the RBR and let it sync.
