mikeymikemik3
Feb 17, 2022Tutor
Orbi RBS350 Continously Blinks White
After moving locations, one of my satellites stopped working and the Orbi app is unable to identify it. I already tried doing a hard reset and its just continously blinks white. The firmware versio...
- Feb 17, 2022
Is 3 meters enough distance? I've pressed on the sync button and its blinking white for quite a long time now
Feb 17, 2022Guru - Experienced User
Try at least 10 feet away from the RBR. Next to the RBR is too close.
Is a prior RBS entry on the RBRs web page exist or nothing is seen here?
Press the sync button on the RBS then on the RBR and let it sync.
mikeymikemik3
Feb 17, 2022Tutor
- mikeymikemik3Feb 17, 2022Tutor
it took some time but the blinking is now gone
- FURRYe38Feb 17, 2022Guru - Experienced User
Be sure the FW on the RBS is the same as whats on the RBR.
3 meters is a good distance to do a initial sync to the RBR while in same room as the RBR.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
