cannonballgray
Sep 24, 2021Tutor
Orbi RBS350 leuchtet sehr oft blau, blinkt sehr oft weiß, am Tag und in der Nacht.
Orbi RBS350 leuchtet sehr oft blau, blinkt sehr oft weiß, am Tag und in der Nacht. Das nervt mega. Was kann ich tun, um das Problem zu stoppen?
Sep 25, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
cannonballgray
Sep 25, 2021Tutor
Hi,
- the Orbi RBR350 is configured as the router
- there is the Vodafone Wifi router
currently operating as a modem only.Arris Touchstone TG3442DE - My Home is about 70sqm
- The distance from Orbi RBR350 to Satelite in my sleeping room is less than 30 feet
- Yes, a 1 minute power off has been done with Orbi system and ISP modem. I will do it again.
- FURRYe38Sep 25, 2021Guru - Experienced User
Can you move the RBS a bit farther away, say 35 feet?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Also might remove the RBS from the RBRs web page. Then factory reset the RBS by pressing the reset button for 15 seconds then release. Then resync the RBS to the RBR.
