Wizzard370
Jan 25, 2023Tutor
Orbi RBS353 and WiFi 6
I have the Orbi RBS353 setup, which I understand, is a WiFi 6 mesh. I cannot see any reference to WiFi 6 in the WiFi setup section of the router. How do I enable this please?
WiFi Analyser does not pick up WiFi 6 either.
Wifi 6 isn't 6ghz. wifi 6E is.
Wifi 6 just incluced 2.4ghz/5ghz.
when you go to the 6E you get the 6ghz.
The only mesh from orbi right now with 6ghz is the RBKE963
What do you expecd to see?
Wifi 6 is wireless AX and will show up as increased "up to ****mbps" in the settings. You won't see a "wifi 6" option in the router or your devices.The Wifi Analyser app on my Phone shows 2.4, 5Ghz Channel graphs but the 6Ghz does not show anything.
