BradPruitt
Feb 04, 2021Initiate
Orbi RBS50y V2 wont sync with Rbk752
I am having trouble syncing the outdoor satellite to the new router. Does the RBK752 and the RBS50Y have compatiblity?
- Feb 04, 2021
From what I userstand, the RBSY needs to have Extender mode FW loaded on it, then it should work with Orbi AX systems.
Feb 04, 2021Guru - Experienced User
- BradPruittFeb 04, 2021Initiate
FURRYe38 wrote:From what I userstand, the RBSY needs to have Extender mode FW loaded on it, then it should work with Orbi AX systems.
Thanks, I was going to try that if nothing else worked, but it worked perfectly!
- FURRYe38Feb 04, 2021Guru - Experienced User
Good to hear. Enjoy. :smileywink:
