Bo_Mikkelsen
Feb 27, 2025Aspirant
Orbi RBS750 drops connection every night
Hi My ORBI RBR750 is hardwired to a RBS750 which has started to drop its wifi connection every night, then restarts and drops connection again and again It has done it once before, where it helped...
Bo_Mikkelsen
No lights at all - they are functioning when resetting, but the system turns them off afterwards
The cable is cat 5e
Only the router and one satellite is deployed - with the cable between them, the home is 190 m2 large - I have recently acquired the second satellite - maybe i should employ it and skip the hard wire?
I did try to exchange the deployed satellite with another one - same result
Firmware: V7.2.6.31
Feb 27, 2025Guru - Experienced User
Been posts about v.31 causing problems for users. v.21 is most stable for the 750 series. I'd revert the system back to v.21 and see. Downgrade the RBS first, then RBR lastly. Factory reset and setup from scratch after downgrading. Disable the auto update feature on the RBR to prevent the system from re-updating back to v.31.
