mcnitzken
Jul 31, 2021Guide
ORBI RBS750 no longer stable in v4.6.3.7 - Possible downgrade assistance
Hi, was hoping I might get some help here as after calling Netgear I got met with "Everything appears to be fine", despite the fact the satellite no longer works. I have an Orbi 752 set with 1 RB...
- Jul 31, 2021
I'd actually tried most of these options as I'd seen some of the previous posts and started trying everything out of desperation. I've sort of reached a point of a usable point, although probably not the optimal situation.
the router seems to be stuck on the v4 firmware, but I was able to downgrade both satellites to v3.18 and after a factory reset they connected up and are working normally. So basically I have two different firmwares running, but my speeds are actual normal and the coverage is stable now.
So, while definitely not a perfect option for anyone else stuck with a non working system after v4 you can
1. Go to the RBS750 support page and download the latest v3 firmware (I used the v3.18)
2. Plug into each satellite with Ethernet and manually load the downgrade and run it
3. Factory reset the router and set it up the satellites and internet
4. On one of the satellites I needed to do a factory reset on the satellite as it had a different login password after the downgrade and was showing solid purple.
5. I also set static ips for both of my satellitesIts not 100% perfect as I occasionally see out of sync messages in the logs, but the satellites themselves powered on and connected as blue and after a minute or two the light went out and they both have ~30 devices hooked up to them now with the router having another 40. Everything is getting decent speed tests and is able to work on the network. It's been stable for over 2 hours now, so I'm going to consider this a win as I had at most 5 mins of stability for the last 24 hours.
I'll probably leave my network in this split firmware state and hope that netgear can release some updated firmware that doesn't nuke the satellites soon!
dragonrunner
Aug 08, 2021Aspirant
I'm on firmware V4.6.3.7_2.0.49.
I also had wifi problems. Wired no issue. None of my devices could connect. I changed the wifi password. Verified that I could connect via wifi with my ipad and android phone. Then I changed the password back to what it was and was again able to connect to the wifi. Then all of my other devices connected sucessfully.
Maybe the password hash stored in the router got corrupted. Or simply resetting the wifi settings cleared up the issue.
- FURRYe38Aug 09, 2021Guru - Experienced User
Sometimes a factory reset and setup from scratch is a good thing.
- cugarguyAug 16, 2021Initiate
I have he same issue - nothing has changed in my setup or placement, but as soon as the firmware updated, now my satalite blinks colored lights at me. It never lit up before because it always had a solid connection. I unplugged the satelite and tested the wifi signal strength from the router. It used to be in the 70-100 Mbps range, and now it is around 10Mbps or less. I contacted support, and they said the hardware was fine, so the update must have "changed my configuration" and that it would cost me $100 for the support contract in order to fix it (what a scam). They also mentioned that my 2.4G and 5G were likely switching back and forth on the backhaul, though I don't see where I can control that anywhere.
I tested multiple mesh networks and this one by far has been the best, until this firmware update. The support person re-upgraded my routers and satelites and then had me do a full reset. I seem to have a better signal now, but the statelite is still showing amber, and then blue and then amber again, and the admin portal says it has a poor backhaul connection. I think my next step is to back off the 4.6.3.7 release and see if things improve. I can always reupgrade if I need to.
- FURRYe38Aug 16, 2021Guru - Experienced User
Try removing the RBS from the RBRs connected clients page. Factory reset the RBS by pressing the reset button in back for 15 seconds then release. Power OFF the RBS and take it to the same room or near the RBR. Power ON the RBS and try to re-sync the RBS by pressing the sync button on the RBS then on the RBR.
